ASA eur/jpn/usa 2017
Berichtdoor marksanne » 27 nov 2017, 14:52
Het Mitsubishi ASA programma zoals gebruikt door dealers waarmee je eenvoudig elk onderdeel(nummer) van iedere Mitsubishi tot een jaar of 30 terug kunt terugvinden.
[M00] Mitsubishi ASA Japan, update 596 (2017-04-28), 417 MB
[M50] Mitsubishi ASA North America, update 492 (2017-04-28), 211 MB
[M60] Mitsubishi ASA Europe, update 512 (2017-04-28), 336 MB
[M80] Mitsubishi ASA General Export, update 476 (2017-04-28), 443 MB
Avatar gebruiker
Geregistreerd: 05 maart 2012, 14:11
Re: ASA eur/jpn/usa 2017
Berichtdoor marksanne » 27 nov 2017, 14:58
Installatieinstructies (ik heb ze alleen even door de translator heengehaald, niet gecorrigeerd or gechecked):
1. Load the required file(s).
2. We start. By default, the installer suggests installing the program on the C: drive.
If there is a necessary space on the C: drive (it will be indicated in the installer window), it is better to agree with it, otherwise you will have to manually correct the configuration files (see clause 5).
We click on the "Extract" button, wait for the end of the unpacking.
3. Make sure that the installer has copied the ASAMAIN.ini file to the C: \ WINDOWS directory.
If there is no ASAMAIN.ini file in the C: \ WINDOWS directory, it must be copied there manually from the C: \ MMC \ ASA folder.
4. After installation, the label "Mitsubish ASA (region)" appears on the desktop.
Clicks label.
When you start Mitsubishi ASA will give out two windows with warnings:
In either case, click the OK button or press Enter.
The application will start, you can work.
5. If you selected another drive (for example, D :) to install, you will have to do the following:
Note: When changing the destination drive, leave the rest of the path untouched, for example, D: \ MMC \ ASA.
5.1. In the C: \ WINDOWS folder, open the ASAMAIN.ini file for editing.
5.2. In this file, all occurrences of C: change to D :.
5.3. We save the file, we launch the Mitsubishi ASA.
5.4. After starting the program go to the menu File, Setup, and in the opened window in the field "Directory for user settigs" we specify the path D: \ MMC \ ASA \ M .. \ Users (M .. - do not change, maybe M00, M50, M60, M80 depending on the region).
5.5. Click Ok, the application will restart. You can work.
Avatar gebruiker
Berichtdoor menno3x8g » 27 nov 2017, 20:00
De bestanden zijn (nog) niet downloadbaar Mark.
(The requested URL /files/A5A/MMC_ASA_M00_596.exe was not found on this server.)
Avatar gebruiker
Geregistreerd: 07 maart 2012, 21:21
Woonplaats: Groningen Ommeland
Berichtdoor marksanne » 27 nov 2017, 20:52
Huh!? Wat is dit nu?
Ik heb even geen idee waarom de linkjes niet werken. Ze zijn qua folder/map en opbouw precies gelijk aan de oudere ASA file die je hieronder in het lijstje ziet staan, ook dezelfde permissies, etc...
Mijn kennis schiet te kort blijkbaar. Iemand met suggesties?
Avatar gebruiker
Berichtdoor Uray25 » 02 dec 2017, 18:57
zo snel uit het hoofd, denk ik dat de bovenliggende folder nog wat restricties heeft...
Geregistreerd: 07 maart 2012, 20:16
Berichtdoor foks » 05 dec 2017, 21:05
het wonderlijke is dat MMC-ASA.zip het wel doet.
het plaatje "/files/A5A/EUR/a5a-eur-a.gif" doet het ook.
Zitten we niet naar een oude (niet gesynchroniseerde) versie van /files te kijken ?
zelfs dat asa-all.jpg plaatje schijnt niet aanwezig te zijn.
1991 Galant GLSI HB 2.0L automatic
wie is foks?
Avatar gebruiker
Geregistreerd: 07 maart 2012, 21:08
Woonplaats: capcity
Berichtdoor Uray25 » 09 dec 2017, 14:23
Is de Upload dan eigenlijk wel succesvol voltooid ?
Keer terug naar Handboeken
Wie is er online
Gebruikers op dit forum: Geen geregistreerde gebruikers. en 1 gast
