ASA eur/jpn/usa 2017
Het Mitsubishi ASA programma zoals gebruikt door dealers waarmee je eenvoudig elk onderdeel(nummer) van iedere Mitsubishi tot een jaar of 30 terug kunt terugvinden.
Klik met je rechtermuisknop op de linkjes en kies zoiets als 'link opslaan als'.
[M00] Mitsubishi ASA Japan, update 596 (2017-04-28), 417 MB
[M50] Mitsubishi ASA North America, update 492 (2017-04-28), 211 MB
[M60] Mitsubishi ASA Europe, update 512 (2017-04-28), 336 MB
[M80] Mitsubishi ASA General Export, update 476 (2017-04-28), 443 MB
Een alternatief (zolang het werkt) is deze site:
Re: ASA eur/jpn/usa 2017
Installatieinstructies (ik heb ze alleen even door de translator heengehaald, niet gecorrigeerd or gechecked):
1. Load the required file(s).
2. We start. By default, the installer suggests installing the program on the C: drive.
If there is a necessary space on the C: drive (it will be indicated in the installer window), it is better to agree with it, otherwise you will have to manually correct the configuration files (see clause 5).
We click on the "Extract" button, wait for the end of the unpacking.
3. Make sure that the installer has copied the ASAMAIN.ini file to the C: \ WINDOWS directory.
If there is no ASAMAIN.ini file in the C: \ WINDOWS directory, it must be copied there manually from the C: \ MMC \ ASA folder.
4. After installation, the label "Mitsubish ASA (region)" appears on the desktop.
Clicks label.
When you start Mitsubishi ASA will give out two windows with warnings:
In either case, click the OK button or press Enter.
The application will start, you can work.
5. If you selected another drive (for example, D :) to install, you will have to do the following:
Note: When changing the destination drive, leave the rest of the path untouched, for example, D: \ MMC \ ASA.
5.1. In the C: \ WINDOWS folder, open the ASAMAIN.ini file for editing.
5.2. In this file, all occurrences of C: change to D :.
5.3. We save the file, we launch the Mitsubishi ASA.
5.4. After starting the program go to the menu File, Setup, and in the opened window in the field "Directory for user settigs" we specify the path D: \ MMC \ ASA \ M .. \ Users (M .. - do not change, maybe M00, M50, M60, M80 depending on the region).
5.5. Click Ok, the application will restart. You can work.
De bestanden zijn (nog) niet downloadbaar Mark.
(The requested URL /files/A5A/MMC_ASA_M00_596.exe was not found on this server.)
Huh!? Wat is dit nu?
Ik heb even geen idee waarom de linkjes niet werken. Ze zijn qua folder/map en opbouw precies gelijk aan de oudere ASA file die je hieronder in het lijstje ziet staan, ook dezelfde permissies, etc...
Mijn kennis schiet te kort blijkbaar. Iemand met suggesties?
zo snel uit het hoofd, denk ik dat de bovenliggende folder nog wat restricties heeft...
het wonderlijke is dat MMC-ASA.zip het wel doet.
het plaatje "/files/A5A/EUR/a5a-eur-a.gif" doet het ook.
Zitten we niet naar een oude (niet gesynchroniseerde) versie van /files te kijken ?
zelfs dat asa-all.jpg plaatje schijnt niet aanwezig te zijn.
Is de Upload dan eigenlijk wel succesvol voltooid ?
Hier een link naar andere Mitsubishi enthousiastelingen als je een prijslijst wilt toevoegen aan ASA. Je kan ook heel makkelijk zelf een prijslijst opmaken in een tekst file. Hier staat beschreven hoe je die dan in ASA kunt invoeren. Let wel op dat je tekst file in alfabetische volgorde is anders werkt het niet.
Ik weet niet wat ik eerder fout heb gedaan, maar de bestanden staan er nu opnieuw op en lijken te werken!
Terug naar “Handboeken”
