230mm or 225mm clutch disc?
My clutch is near its life and I found a really good deal on a clutch kit, but it's 230mm - been comparing it to the other 225mm and I am wondering if it will fit?
Re: 230mm or 225mm clutch disc?
What's the VIN of your car?
Eigenaar van de enige in NL geregistreerde 8G Galant PFL die nog in bezit is van de eerste eigenaar.
Eigenaar van 1 van de 6 in NL geregistreerde 8G Galants die nog in bezit zijn van de eerste eigenaar.
JMBSNEA5AVZ000699
According to the MMC ASA database, your car is equipped with a 225 mm Excedy clutch kit.
Replacement with a 230 mm clutch plate, even if it would fit, affects the clutch cover and the flywheel wear circle.
All the more for that reason, I do not think it is wise to mount a 230 mm clutch kit. According to information from Exedy Europe, the right set for your car would be Exedy MBK2052
You're a lifesaver, thank you so much
